MedMan
I have always had problems in fitting a fully-automatic bilge pump that I could rely upon due to the configuration of my boat's hull. I am hoping that forum members may be able to help me solve them.
My boat is a Trident Voyager 35. She has a full length keel as shown below:
There is a glassed-in tray in position A extending all the way from the ballast to the stern. The only holes in this tray are a 25mm drain hole below the engine, a 50mm hole for the pipe leading to the manual bilge punp and a 25mm hole for the pipe leading to the electric bilge pump. The void below the tray is approximately 1 metre deep and 2 metres long and it is 10cm wide at the bottom and 70cm wide at the top. That is quite some void with the capacity to hold a lot of water!
My problem is where and how to site an automatic switch to control the pump. I have already concluded that it will have to be an electronic switch rather than a float switch, but where and how do I mount it?
