geem
What is the manufacturers rating of your pump? Its not much help to us on the forum if you dont tell us the rating of your pump or how its installed. Of your electricsl pumping capacity is less than your manual pump then you need to seriously consider uprating your pumping capacity.My only experience of a leak at sea last year completely overwhelmed the Jabsco pump. Even after 4 hours of continuously clearing the filter as every bit of underfloor debris floated into the sump it could not even half keep up so needed one of the two of us to use a jug from sump to sink continuously.
The other had to keep a lookout and dive into the nooks and crannies to identify the leak.
I hadn’t used the manual pump for years and weirdly didn’t consider it as a serious help for a few hours. Then found it was way more powerful than the electric one - and the combination of much wider pipe and no filter helped I think.
We had wooden bungs but as I could see no leaks in any of the 11 seacocks or in the hoses to their destinations I’d started down a Cheeky Rafiki thought process.
