pvb
The plastic bits do.
The plastic bits might fade a bit in colour, but they won't suddenly disintegrate into dust - at least, not in most people's lifetimes.
A tonneau type cover to protect the stuff on the deck, exposed rope, clutches etc might be worth thinking about.
I would rather see the dirt , frost / ice , snow , bird shit on my cheapo buckets rather than on the winches when i visit over the winter , ropes / lines are already bagged ??Our covers are like a simple drawstring bag.
A few minutes to make on a sewing machine.
We used to be in Portsmouth Harbour so the rain could be quite dirty.
I think the Gosport shitehawks used to perch on the edges of the winches and crap in the socket..
Winches are not cheap. Even a service kit costs a lot more than a metre of fabric.
Seems like a small bit of effort to look after something you depend on.
What are M and S tubs?I was thinking of sticking fabric over my M&S tubs to smarten them up .
And don't forget the MOB kit.Start a 'thing'....
Make up some sheet winch covers in fabric to match your facemask..... ( make up a spare. You know why ) then make up a matching windlass cover, then one for your outboard motor, then another one for the windvane.... then another for the anchor on the foredeck.... then your cockpit instruments, too, and......
It's gonna be a long winter.
We have two sets of lifebuoys.And don't forget the MOB kit.
That one's serious. I've just had to throw away a horseshoe buoy because UV's destroyed the cover. The next one will have a cover, as will the throwing line bag, which used to be dayglo red and is now RYS trouser pink.
Same as hatch covers when you leave the boat. I suppose some of you dont cover your hatches?
Most of my boats have been dinghies.See post 30.
A minor pain to put on but boy, magnificent things cockpit covers:
When you arrive at the boat, after heavy rain, things are dry and fairly clean.
You can leave locker lids open to promote huge ventilation through the boat.
Wood cockpit seating can be as good as new after decades.
Your instruments will look box fresh for as long as you keep them, covers not required.
Prying eyes are kept at bay, a minor but useful disincentive to thieves, esp on a mooring.
There is less water around to drive it's way into the cabin.
Brightwork stays bright, I have varnished my washboards twice in 25 years.
..........plus if you get the sprayhood down and under your cover and you can forget about ever buying a new one.
Well worth servicing if they have not been done for 10 years. You may find a broken or bent pawl spring or even a broken collet. The grease might quite caked by now. It is an easy job and quite satisfying to have done. Of course make sure you do not drop any bits overboard...............Ah, another of my weaknesses. I don’t service mine, although I have all the kit to do so. When one goes I will carry on with the others until I reach port and service it then. This has saved me 10 years of effort so far as all still work fine.
Thanks and appreciate the advice. I used to dismantle and service winches every year so I am sure it will come back to me. But like many habits I’ve gradually given up doing things which I can’t see a benefit in. The earlier comment about an injury from a winch suddenly spinning freely the wrong way has got me thinking as previously I’ve just had jammed ones.Well worth servicing if they have not been done for 10 years. You may find a broken or bent pawl spring or even a broken collet. The grease might quite caked by now. It is an easy job and quite satisfying to have done. Of course make sure you do not drop any bits overboard...............
A bucket with some white spirit and a tray to put bits on is all you need. Nitrile gloves are nice for your hands. Take pictures at each stage of dismantling
TS
I don't; why would I want to cover the hatches? They are robust and watertight. If covers were essential they'd surely be supplied as standard equipment.
