Badger
Anyone had any experience of fitting and using one of these ? Is it a nice to have or a must have ? Anyone tried the new Moduline Aquadrive ? Thanks in Advance.
earlybird;2225605 said:Much the same result can be achieved using a Bullflex coupling which I have on my 1GM - which jumps around even more! Might have gone down the Aquadrive route but no space - and not sure now it would be worth the extra cost and work.
It was a while back. I did consider a Bullflex, but, IIRC, although it catered well for angular misalignment, it didn't really accomodate radial movement, so I concluded that the Aquadrive was the better engineering job. Must agree that it was fairly pricey and considerable effort.Much the same result can be achieved using a Bullflex coupling which I have on my 1GM - which jumps around even more! Might have gone down the Aquadrive route but no space - and not sure now it would be worth the extra cost and work.
Could I ask how long that shaft was, Tranona?
The overall shaft length from memory is just about a metre with less than 200mm inboard of the stern tube. Take out the 110 mm for the Volvo seal and there is not much left to fit the coupling! About 40mm exposed shaft.
The stern tube is a Stuart Turner which I had to keep because it would never have come out of the deadwood and skeg. If you remove the inner bearing which was originally white metal and a stuffing box there is insufficient clearance for the engine to be fully flexibly mounted - the shaft hits the tube. Final solution was to machine the inboard bearing carrier to take a cut down (about 60mm long) cutless and the outside diameter to take the Volvo seal.
At tickover you can watch the 1GM auditioning for come dancing and the shaft stationary!
