Anyone removed treadmaster?
milltech
31 May 2001
Worcester
www.iTalkFM.com
Does it come off easily? How is it done? What's the mess left behind like and how is it best dealt with?
The idea is to replace with new the same. It's laid onto wood planks.
<hr width=100% size=1>John
<A target="_blank" HREF=http://www.allgadgets.co.uk>http://www.allgadgets.co.uk</A>
Heckler
24 Feb 2003
watched my neighbour in firmhelms yard in pwllheli do it. it was stuck to the cockpit floor with "evostick" type glue, he used a hot air gun and a wire brush sander to remove it
stu
<hr width=100% size=1>http://www.beneteau-owners-association.org.uk
Cantata
1 Aug 2003
Swale/Medway
I just painted mine with the 'proper' paint from Treadmaster. Normally v. expensive but found some in a sale. I am astonished at how good it now looks although obvously time will tell if it wears well. I'm just mentioning this in case paint would be a more economical option for you.
steve6367
28 Apr 2003
Bournemouth, Dorset, UK
www.ybw.com
Am in the middle of this, not too bad if you use a hotair gun and take it slow. I guess it should be easier if you are putting it back. I am painting some parts so surface has to be perfect.
Mudplugger
12 Jun 2003
East Coast/ North Sea
Not Easy!!!!, particularly if it has been laid proper like!, got thumped in the stern a year or so back and pushpit and Treadmaster damaged....took me three days of heat gun, chisel( which blunted quickly,) and belt sander to get good enough surface for repair work.. Tony W.
<hr width=100% size=1>Tony W.
milltech
31 May 2001
Worcester
www.iTalkFM.com
Seem to be different experiences
Thanks for the responses, some people seem to have found it easier than others, is the problem getting it off in the first place, or in cleaning the deck afterwards?
This stuff is VERY old, the boat is a retired lifeboat, but I could not say when the deck treatment was done or whether it is original to the boat, probably not.
The more information the better. I plan to have a yard do it, but I'm very interested in trying to work out how difficult and expensive it will be!
