Neeves
I agree with Tranona. You only need to sand the hull to provide a key for the primer, once - let the yard do it, let the yard sort out the waterline. Next time you will need a power wash, commonly done by the yard (for which you pay), vessel placed on stands and the next coat of AF, in a years time might easily be put on top of this first AF (though you might enjoy sanding down yourself (but I think it unnecessary). When the yard make this first foray into AF for you - I'd hang around and watch what they do.
International tend to be the most expensive AF, or one of the most expensive, and maybe you could save a bit by using cheaper. I'd ask locals to you, or where you venture out, and see what AF they use.
AF works best if applied generously, skimping saves money (short term) but means the AF will not last as long.
I think you need to ask what treatment they are going to give to your prop etc - Propspeed has made big inroads into the MOBO market - but its not cheap (either to buy or apply). If you have a fouled prop - you will be going no-where quickly and your hull will also foul as a result of the low speeds. Regular usage and that generous coating, min of 2 coats, is the way to go.
On doing it yourself - we also found it immensely satisfying - you start of with a really grotty hull but then you finish she will look lovely.
Jonathan
Jonathan
