K80
New Member
Now I'm trying to remove the white bushing but I can't remove it, do you know if it's glued with sika? Thank you very much
Paul for your help bye
If you are referring to the white top bearing that is removed from the inside of the boat then after removing the 4 screws I only had to break the bond of the sealant under the top-hat. The stock will not drop out/down if the skeg bearing is still in place. Once the bearing is out, there will be a lip seal inside the bearing. What is not obvious is how you get this lip seal out:- there is a plastic ring, made of the same material/colour as the rest of the bearing, that you leaver out. It will pop out and pop back in again after fitting a new seal. You have to look very closely to see the join between the ring and the bearing. The lip seal dimensions are:- 40x52x7 and must have a stainless steel garter spring. I paid just GBP4 from a local bearing shop.Now I'm trying to remove the white bushing but I can't remove it, do you know if it's glued with sika? Thank you very much
