Richard_Blake
... double-ended, decided on for gaffer. Main around 475 square feet, long counter aft of rudder post, where the central block mounting will be. Eyebolts on side decks, outboard of rudder post. Tails will run forward to samson posts at aft corners of cockpit (we've discovered the tugboat hitch - great for cold weak fingers and wet lines.). My question, because I'm planning ahead while re-framing the counter and can adjust strong points accordingly, is: do we go for a horse, or choose that buffer system with two shackle-like things sliding on steel bar compressing chunks of rubber? I'm leaning towards the buffer, largely to minimise clutter on deck, but I'd be interested in people's experiences. Does a horse, in our case maximum 2 feet long, have real advantages in terms of vertical pull direction, for example? Can a buffer really make a shock-absorbing difference in a gybe?
Thanks in advance
Richard
<hr width=100% size=1>LowTech
Thanks in advance
Richard
