Robin
Our new boat has a Yanmar 3GM30F engine which is freshwater cooled. Should we change the engine zincs on this, is it necessary when not raw water cooled?
The boat is kept in the water year round in Florida so freezing risk is very infrequent to non-existent and even if there is a very rare frost the boat still sits in relatively warm water (currently 72F). SO should we need to replace the antifreeze mix in the freshwater system which is quite possibly past it's usual recommended change date ( P.O was hopeless and the engine only has 1200hrs on it so he most likely would have left it) Iam aware there are some corrosion inhibitors in the antifreeze mix, so is that a reason to drain and change on it's own??
