Ships_Cat
Did the same with beach test videos some time back - all the other anchors on moist sand (so grains held together by surface tension), Rocna in saturated sand so no surface tension - big, big difference between moist sand and saturated sand as anyone who has tried digging in both will attest.
When the link to the videos was put up some time ago this was commented on by a number who viewed them. Didn't see the tests in real life though, just the videos. A knowledgeable manufacturer would have recognised the problem (whether one of appearance on the video, or one of attempted trickery) immediately - I suppose, in the end, beach tests are always of questionable value, just from the surface tension effect on the moist sand which is not an influence under the sea.
Regarding the anchor weight on the Chico 40's - my own boat of same length carries a 60lb plough as main anchor in order to be independant with an older generation anchor, I suspect they did not and so were under anchored in my (and my friend's) view and manufacturers own recommendations are usually (always? for independant vessel) on the quite light side (have a look at the Fortress recommendation for an around 130 foot boat as I had cause to do recently for a new build MoBo - eeeek!!! - am not criticising Fortress anchors, just the size).
I think a relevant point amongst what I, and I think sbc say regarding weight - I had a look today at a Delta on a cruising free ranging independant boat similar size to our boat and was probably adequately fitted as the Delta was probably several sizes bigger than recommended by manufacturer. Area of the anchor was probably quite similar to our own plough so probably the main penalty we pay is in weight (maybe 20 lbs) which is not a big problem for us (never had a problem with setting). Sorry for all the "probably"'s in that but working from a jaundiced eye.
Not saying I would not go to a Delta (or something /forums/images/graemlins/smile.gif) if replacing our anchors now or commissioning another new build for ourselves (that ain't goin' to happen /forums/images/graemlins/smile.gif, once is enuff for the bank balance) now that newer generation anchors are available but above comments just an indication for comparison purposes. I do, however, tend to sympathise with sbc that there is some merit in weight for setting.
Looking around tho', goodness, some pretty small anchors on some yachts, no wonder some peeps have problems [aghast smiley here] and make a rush for the moorings down in the Sounds (interesting squabbles over them at times /forums/images/graemlins/smile.gif).
Whatever, I respect your views GMac so am not a nasty scratchy cat with you /forums/images/graemlins/smile.gif.
John
John
