jimi
I've got loads of old climbing rope, is that any use as anchor warp or is the stretch contracting going to act as a powerband to rip out the anchor?
Should be alright for a halyard?!![]()
Only if you want you sails to hang down when you sheet in
I think stretch in an anchor warp is pretty much always a good thing in that it minimises peak force on the anchor. Indeed this is the argument in favor of mixed rode (ie chain + warp) over all-chain.
However I'm very skeptical that climbing ropes are at all suitable for anchoring.
1. Breaking strain. The breaking strain of dynamic climbing ropes is usually in the region 7 - 10kN (see for instance mammut 10mm 'super-dry'). Compare this to 10mm anchor plait from English Braids which is 24kN, and the more usual 14mm dia is 38kN. I think you need > 10kN for anything over 24' or so.
shock absorbing is what counts, and it's the boat which will benefit from the surge, since the anchor should be relatively static.
Thanks all. I'll keep 'em for something else other than anchor warp!
