GHA
yes, and to add to the mix remember with dynamic loads that it doesn't take much horizontal movement even in quite deep water to go from a bit of chain on the bottom to bar tight when relying purely on catenary to act as a shock absorber, the force goes up exponentially as opposed to a snubber where its more linear.No. It is the belief that catenary is not enough in water <30-40 feet with short scope that has been thrown out. I've done snubber testing for a magazine article (I use on 35' long) and I like high grade chain.
However, it is also easy to prove (calcultation or observation) that in 40 feet with 5:1 scope the chain will stay very near the bottom and that there is some curve to absorb shock. The point at which it is not enough depends on wind strength, depth, chain grade (weight), scope, exposure to waves, and how much shock is acceptable, with no single simple solution. Of course, since most of us anchor in <20 feet, the point is moot. I generally anchor in <7 feet, so I use a long snubber.
