Andrew_B
I am going to install an electric anchor windlass this winter but I'm not sure yet exactly which type I should be looking at.Ideally I would prefer a horizontal model but the only place I could install it would leave the motor in the anchor locker with a plastic box surrounding it.Is this too exposed? Should the motor ideally be mounted through the deck outside the anchor locker?
Another option might be a compact above deck model but I have yet to see one capable moving 10mm chain +18kg CQR+ 5.5 tonnes of boat (probably nearer 6.5 tonnes when cruising) that wouldnt take up too much deck space.
Also I have been looking at 1000w models - Is this the right size? (I would rather over do the power than burn the thing out)
Any advice welcome before I go and spend the dosh.
Many thanks
Andrew
<hr width=100% size=1>
Many thanks
Andrew
