GHA
So who has snapped a snubber & how did it fail?
Guessing chafe would be high up the list.
I have snapped quite a few. It is difficult to know the cause.So who has snapped a snubber & how did it fail?
Another thought to add to the mix - slow the boat down!
So considering having a look at the feasibility of adding some spare jordan drogue cones to the chain somehow - worst blow I've been in so far was wind gusting 60Kts from all directions so the boat would fly off to the other side of the anchorage , no load on the snubber then lots!
With kinetic energy = mass x velocity squared, if you reduce the speed by 10% then the energy is nearly 20% less, reduce the speed by 20% and energy is down to 64%. Thats a substantial reduction in force if it's possible.
So considering having a look at the feasibility of adding some spare jordan drogue cones to the chain somehow - worst blow I've been in so far was wind gusting 60Kts from all directions so the boat would fly off to the other side of the anchorage , no load on the snubber then lots! ...
The greatest correlation seems the length of time the snubber is used in strong wind. Say more than 5-6 nights in strong wind (say 40 knots+) and the chance of subsequent failure in the next strong wind becomes greater.
It has been suggested the great elasticity of nylon fibres together with salt crystals inside the rope causes the fibres to rub together and chafe internally. Others have suggested there is some internal heating of the fibres which weakens them. I have no idea if these mechanisms are plausible, but In practical terms I am suspicious of nylon snubbers that have been worked hard, even if they look fine.
I have met other cruisers that have experienced similar problems and others that have used the same snubber for many years.
Perhaps the combination of a large anchor with relatively thin chain is a factor making the snubber work harder in my case? Perhaps the nylon has been poor quality? There are a lot of possibilities with no definitive answers.
For chafe I use one of these.
http://www.accastillage-diffusion.co.uk/catalog/Cordage-max-14-mm,9351.html
We then went through the process of adding rubber devices, complete waste of time (and money) and they are heavy for the usefulness they provide.
I'm curious about this - why did the rubber snubbers not work? Apart from the ends tearing out on the badly designed ones, they worked quite well in marina mooring situations with swell and are commonly seen on boats moored permanently on swinging moorings. I was going to add one to our shortish nylon snubber next to try it out, but perhaps there's some obvious reason why it won't work that I'm missing?
The normal ones, cfr Trelleborg, Forsheda etc, will stretch to their maximum with a relatively low load, a couple of hundred kgf at most, while the guys above are talking about tons.
Exactly
I tested a Forsheda one (like a dog bone) and a Shockle. If you set them up as instructed, with 3 or 4 turns round the Forsheda device (or the loop of spare chain for the Shackle) then they absorb the same amount of energy as 2m of the nylon used in concert, and I know which is cheaper (and lighter). But they have a finite limit, set by the 3 or 4 turns and beyond that you are using the elasticity of the rope or have straightened the chain. You can increase their ability to absorb more shock with extra turns - and then they break.
So - they have a finite limit to shock absorption.
John Knox, of Knox anchor fame, also tested a Forsheda device and came to the exact same conclusions. It might be on the Knox Anchor website.
The rubber devices are useful in a mooring application because they are shorter, for about 400mm of dog bone length they absorb that same amount as 2m of nylon. You could get the same amount of elasticity in nylon - but it would be too thin.
And I see a surprising number still attached to the line but the rubber device is broken.
As has been underlined 10% stretch on nylon is a sensible WLL for a 10m (or I prefer boat length) line, if you want 'more' stretch in terms of metres then have a longer snubber - it will last longer and you can use the system to higher wind speeds (negating the need to have a storm snubber and a means to attach it). If you use much shorter than 10m then there will simply not be sufficient elasticity and if you use a 2-3m length of nylon then you effectively have no elasticity at all.
More is better - ignore the ideas prompted by the need to disagree on principal and without any foundation. Many yachts are equipped with short lengths of chain, sometimes only 10m, and have anything upto 100m of line - which they use as a single anchor rode. They do complain that the line allows them to wander about in light winds - but they never complain the system does not work in strong winds. A long snubber combines the benefit of lots of elasticity whilst still employing all chain - and if you set up such that you can vary snubber length the problem of wandering about disappears. If you commence the snubber at the transom you have yacht length of snubber and the hook can be just under the bow - not dragging on the sea bed where it might fall off (and dragging on the seabed, common on long snubbers commencing at the bow will abrade the snubber).
A boat length snubber will be good upto about 30 knots - beyond that and you will start to exceed the 10% in gusts. So for most people most of the time 10m or boat length is about right (as most people do not anchor and measure 30 knots at the masthead).
GHA's drawing at the outset of the thread is the way to go - but there are lots of refinements to that initial drawing. Much depends on your deck layout (some yachts have fairleads with little sheaves set into the toerail (for mooring lines) but they would be ideal to get the snubber outboard). But consider longer than GHA first proposed (think his initial ideas were based on a 20% stretch), consider working to a WLL 10% stretch (and if you go to 15% it will not matter too much) and think of longer, like double, boat length (ours are almost 3 x boat length and we have a bridle - so 2).
We coil and store the extra snubber in exactly the same way we do headsail sheets, reefing lines (or any other spare cordage).
If there is any friction in your system then try to introduce turning blocks or covers, if you read some of Thinwater's work in PS, or his blog, you will find he has some excellent ideas on covers for snubbers.
http://sail-delmarva.blogspot.com.au/2017/01/the-book-store.html
Indoor rock climbing walls are a good place to try to source retired rope - you should get them for free. You will need to find a high wall to source 30m lengths - it is impossible to sensibly join climbing rope - you need one piece, for a small yacht try to find 8mm rope, for larger yacht 11mm rope.
Jonathan
....Minimalist wallet - go for nylon (and get to your local climbing wall quickly and recycle the longest ropes they have). Its better than the retired ropes going to landfill.
I interviewed a bunch, correlated non-chafe failures to a formula, and it became quite clear that shorter snubbers (<20 feet) and too thin lines were the cause. The engineering is not that complex, but the rope has to be long enough to absorb a wave. This generally means at least 35' long and about one size thinner than the fiber rode that would be specified for the boat (1-2 sizes for catamaran bridles, but still only one size for mono, since they single leg load more often). In this way the working load is only about 10% of BS at 50 knots, which they can endure for a long time...
