graham
Which ever swivel you use avoid fitting it direct onto the anchor .Thanks. I have read your article about swivels. Is there a budget swivel you could recommend, or its better to go for expensive one?
If you slide the jaws over the anchor stock and put the pin in its fine for a direct straight line pull but if the wind or tide changes you could be pulling on a big angle which could bend the jaws in the swivel.
A short bit of chain between the swivel and the anchor will avoid that happening.
