Murv
I've recently replaced one of the alternators on my twin engine mobo.
The connections on the back are (obviously) completely different. I've installed, the alternator, everything is working perfectly, but I have a mystery wire left with nowhere to connect it to.
It runs from a "split charge switch," when the switch is on, the wire is at the voltage of the second engine's battery bank, can I connect this wire to the main positive terminal on the new alternator? And if i do, does this just give the capability for both alternators to charge both battery banks, spreading the load between them?
