bendyone
I have been having problems with the alterator on the Nanni. It is (was) a 60A fully insulated unit. However I decided to replace it with a car type. An Astra one fitted OK but it only has 2 terminal B+ and D+ also a - ground stud. I fitted it yesterday with the B+ going to the battery and the - sutd to the engine earth. The wire from the inst panel to the D terminal at no stage showed any voltage so I left it disconnected. ( I think the charging light circuit, a diode/resistor is broken)
On running the engine the alternator charged the battery shown by 15Volt on the battery. I therefore assume that the alternator is self exciting.
Rather than replace the control panel should I just connect a small bulb from the starter switch to the D terminal on the alternator? If so what rating should the bulb be?
