boatmike
I bit the bullet and talked to the guy from Crucial WiFi this morning. He was very honest and said that setting up the two components of the Alpha kit was "not straightforward and can be tricky if you are not very computer literate" I asked him if there was anything on the market that worked straight out of the box. He was less forthcoming on this but finally admitted that there was but it was more expensive. Then I phoned the guy from Kuma. Their kit according to him does not use any components made by Alpha and there is no connection between the two companies. His kit does indeed use a directional antenna so won't work at anchor, but I don't need that so don't care. He did say that the directional ariel needs to be pointed in the right direction but if it is can pick up signals up to 1.5 km away. More to the point he said that all you need to do is take it out of the box and plug it in and it works. You then log on to the router and get a series of signals to choose from just like using a normal PC without the booster. Yes it costs £150 against the £100 from Alpha and if you want the 3G dongle as well (which I don't ) can cost £210 so I suspect that this is the kit that the guy from Crucial was talking about when he said it could cost up to twice as much to achieve working straight out of the box. Anyway I have bitten the bullet and ordered one so will let you know how I get on with it......
BTW I looked at the Wirie website but at $650 for the basic kit it's a bit b****y expensive innit?
