JumbleDuck
They're very popular amongst drug dealers, apparently.
I'd be surprised, with only 1g resolution. I have some micros scales from Maplin which go down to 0.1g. Also much easier to hide when the rozzers approach.
I would be surprised if something that can weigh up to 5kg will accurately weigh a few grams.
Be surprisedThe cheap 5Kg scales I use for epoxy accurately weigh euro coins down to 1g.
What was a great idea. However, I do doubt the accuracy and precision of the device when it comes to measuring small quantities of your resin and hardener. If the accuracy of measurement is not your concern, then you are good with having misreading’s most of the time. However, you could purchase more sensitive devices or better still get your hands dirty a little bit if you are a technical person. You could construct your own sensitive low weight measuring device by simply purchasing a strain gauge device, bonding it to an elastically deformable platform and then set up the electrical connections. Then you can get some already made electronics to process and display the readings.
Learn more about this in the attached link and you could also order custom solutions from the manufacturer in the link.
Buy Different Load Cell Types, Conditioners & Amplifiers | Tacuna Systems
https://tacunasystems.com/knowledge-base/force-measurement-tips/how-to-build-digital-weighing-scale/
You may be right. I will test it and report back.
Although I am less concerned with knowing the weight accurately in grams than that the ratio of hardener to resin is accurately 1:5.
I bought these earlier this year, and find them plenty accurate for small quantities of resin: https://www.amazon.co.uk/dp/B01JKX4QAC/
In fact I have found less accurate scales adequately accurate for weighing 20g of resin or even less.
I use scales for epoxy. I zero an empty container then drip in the part A till i have 4/5ths of the total weight i want.I hope you use different containers (of the same weight) for the epoxy and hardener?
Since both are a fairly "thick" liquids how do you measure the weight of the epoxy/hardener left on the sides of the container or do you use a brush to "scrape" both containers clean?
deleted
That along with a container of oxalic acid crystals should get the attention of HM Border Control if you get pulled!https://www.aldi.co.uk/crofton-digital-scales/p/086864253274300
I bought one of these for weighing small quantities of epoxy resin and hardener.
Good value at £6.99, including battery
That's exactly why I returned it to Aldi after a few days!one thing I found with those Aldi scales is the auto power off is very short and if your 1/2 way through pouring your precious resin your goosed if you did not 1)Remember the weight of the container and 2) have a close eye on what weight was poured just before it powered off
John the Kiwi (post #30) explains the technique I use.I hope you use different containers (of the same weight) for the epoxy and hardener?
I have always measured by graduated medicine cups and have no problems with larger quantities (say) 60:30 but I have real problems with small quantities (say) 20:10. When I finish the epoxy container invariably there is virtually nothing left in the hardener container. Some manufacturers give the ratios by weight and others by volume. Apparently some manufacturers don't consider the change in volume caused by temperature change to be significant
(Wherever I can I will use polyester in preference to epoxy)
Yep! I saw that> Thanks. (You'd know my mate Paul Lunberg?)John the Kiwi (post #30) explains the technique I use.
I used to mix epoxy in disposable paper drinking cups but now I use paper ice cream tubs. These are cheap from eBay and the larger base area makes it easier to mix in fillers as well as giving a few moments more time before the mix starts to set.Yep! I saw that> Thanks. (You'd know my mate Paul Lunberg?)
