oldbilbo
Now how did they know I'm starting to think about antifouling....
Roller far two big for a/f.....much easier with the 4inch mini rollers/trays (usually £1.99 with 4 roller heads).
B&Q value rollers, but 4inch is a good size. you can hold the 4inch tray in one hand and the roller in the other.
the smaller rollers are easier to remove and replace, and you don't waste so much expensive antifoul when you
change them.
I use the B&Q value rollers, which are if anything wider than that ALDI one. No problem at all, and why would you not want to cover as much area as possible with one stroke?
The solvent in my A/F caused them (B&Q rollers) to disintegrate in a very short time!
..... i can get around 37` in 30 min`s
Wot you doin' on Saturday....?![]()
Ok, but that doesn't say anything about their width.
This makes no sense to me, you have a large area to cover, so use the widest applicator.I find the wide rollers apply too much AF...
If you've got a Pole to do it for you who cares how large his roller isi disagree
i use a 7" roller on a pole does me
