Wansworth
I have water exiting from the bottom of the mast or deck collar any idea how to cure it or where the water could be coming from,thanks
Well yes prior to the rain I thought I had cured the leak!
The only way water can get in is through the mast fittings as far as I can see.My plan, as there have been no ideas is to inject foam up the aperture and quicklyblock off the hole .....then drill a few holes in the mast track to the water can drain out.Rain water is degrading the mast bulkhead so important it’s cured.
To avoid a badge we are lowering the mast!
There are plenty of gaps in the mast where it can enter.
If it's exiting externally, then it isn't a problem; if it's coming into the cabin it's probably running down the mast wiring in which case ensure you've formed a drip loop - the water will then exit the base of the mast via the mast step.
There was a recent thread on this in the Yahoo Albin Vega group.
