Trintella
Does / did any of you have one of these petrol engines? If not they are two cylinder four stroke side valves. I have fitted hardened valve guides so it can run on unleaded. Not sure if it is an unusual feature, but No.1 fires, then No.2, then No.1 exhaust, then No.2 exhaust - so not ever going to be that smooth.
I have re-built mine and whilst it now runs there is a fairly irregular, deep, knocking noise when running. It didn't work when I bought the boat so I have not heard it running before.
I doubt it is anything mechanical as all the important parts were measured by a machine shop, the bores were honed and new rings fitted. Compression is good. No nasty mechanical sounds when turning over with the starting handle. In fact no nasty noises when turning over with Dynastart with leads pulled off.
I can't really isolate the knocking noise, I thought it might be coming from the gearbox, but if it was mechanical you'd have thought I would be able to feel the vibration & localise it, but I can't. That's what makes me think it is combustion/timing related.
I've set the timing up per the instructions & played around with it whilst running, the knocking gets worse when the engine runs irregularly, trouble is, if I retard the ignition too far I can't get it to keep running/start.
The throttle spindle in the carb is worn (as is the rest of the carb I suspect), but I have temporarily sealed it with pkf(?) plumbers teflon tape wrapped around the spindle - this makes the engine tick over more smoothly, but does not seem to affect the irregular knocking.
I've heard a Volvo MD20(? - name may be wrong) running in a Pentland & it sounded pretty 'knocky' but then it is a diesel!
Any ideas? Is the 'knocking' just the sound of the engine firing!!?
Giles
Giles
