rickwales
I can see this is a old post but I’m just applying to become a BSS surveyor, eberspacher style heaters will require metal fuel piping to pass BSS, others have made more fuller replies but certainly the fuel line needs to be metal if your needing BSS certification, also pay attention to having a fuel shut off and be careful where you trunk the combustion intake air from (Exhaust protection has been covered well by others) hope that helpsThere has been enough said in the past on here and other forums etc about these Chinese heaters so advice only please.
The 5kW heater is on a test rig and been working for a fortnight on and off heating my workshop(exhaust out the door), running on heating oil. I used 5l of heating oil in 18hrs mainly on low to medium heat.
I've read the Eberspacher installation guide but have the following questions:-
Supplied 10l tank will probably be fitted in the cockpit locker, on a swing out board so can be easily filled. To be fitted with an on/off tap. Heater will be fitted in the stern behind the steering gear on the transom. Four outlets, stern cabin, saloon, heads & fore cabin.
I'll run it on heating oil - can I assume this is legal? (although I do have a fuel tank dip tube but more complicated run).
1) Fuel pipe - can I use the supplied plastic tube or should this be copper tube? not mentioned in the guide. Will be run through side locker and rear cabin under berth lockers, not through engine space.
2) Power cable - from comments it appears the power cable to the battery is undersized, the guide suggests 4mm² for up to 5m combined run and 6mm² for longer. I've got some 2.5mm² which I assumed would be sufficient - the run will be about 8m overall length(but not measured accurately yet). Run from domestic batteries, 2 x 90ah new leisure batteries.
3) Do I need to fit the small inline filter as supplied? According to one site NOT suitable for marine installations. I would have fitted it between tank and tap but maybe after the tank is better?
4) I'm going to insulate all the ducting where possible.
5) I'm also going to fit an on/off switch in the power line to the heater.
Any other suggestions welcome.
