sailinglegend420
Not wishing to fall out on this one but do consider the facts.... Hitachi regulator's temperature compensation is primarily to protect against over-heating of the alternator.
If the temperature compensation was purely to protect the alternator then a very crude temperature cut-out could be used. The Hitachi internal temp compensator is very crude BUT it does have some intelligence and is designed to reduce the output voltage at the rate 0.03v per degC rise in temperature above 25C. So at 40 C it will reduce the voltage by 15 x 0.03v = 0.45v. So the battery voltage will come down from 14.4v to 13.95v. This rate of fall is exactly the compensation needed to stop the battery gassing. At 40C a battery gases at 13.98v.
So if the temperature compensation was ONLY to protect the alternator why have such a precise temperature gradient. This kind of works in a car where the battery is near the alternator, but on a boat the battery should never be anywhere near the alternator so is never at the same voltage. This is why an external regulator with a battery temperature sensor actually on the battery will always charge at the correct voltage and therefore make charging faster and more efficient.
EDIT
40C is not very hot. My Balmar is designed to cut the output by 50% when it gets to 105C!
