Branne
Hi Melida , I have exactly the same problem. How did you end up fixing this issue please?
I have KAD300 and the starboard engine performs well at the beginning at 3400 RPM but after few minutes or if I try to go down to 3200 RPM the starboard engine loses rev and the supercharger kicks in and stays around 2600-2800 RPM.
My Mech changed the Turbo on that engine. Also he found a strange small hole in the aftercooler housing that leaked air. But to me it looked like a hole that was done by the manufacturer. He took it to an engineer and we closed that hole. But when I check now photos of some aftercooler online I found the same hole in these pictures. Maybe it should be there for a reason.
After changing the turbo and closing the hole in the aftercooler housing we went for a spin and the same issue remained there.
I did the service recently and all filters are new. And in order to eliminate the tanks, we used a Jerrycan of diesel and the starboard engine was taking diesel from it instead of the tanks. But same issue...
The hull is clean I think because I just did the antifoling and polishing a month and a half ago and I have been using the boat quite often.
