Jim@sea
Although I have owned a Nauticat 33, I have also owned a Colvic 24, And note what you say about not wanting a Colvic. But when my Colvic 24 was on the hard in a cradle it was parked next to a Fisher 25 and I noticed that at a distance the Colvic 24 did not seem 1 foot shorter than the Fisher 25.I know this has been covered before but would like to revisit the topic with a little 'added focus'...
I'm looking for a small motor sailer. 'Small' means either up to 21' or up to 26' if I am prepared to spend a further £900pa in my marina. Anyway I don't think there are many, if any, motor sailers around 21' or under.
I know they are much loved but I can't afford a Fisher 25 and I don't want a Colvic or a Hardy.
I'd like a boat with 3' or less draft, an inboard, the ability to dry out upright or nearly so and helm positions both inside and outside. £5-£7k. That narrows it down a bit!
Inevitably performance will be something of a compromise but I'm ready for that (honest) and I also know that I may have to compromise on my list of requirements. It is also possible that the boat may not be the sleekest or prettiest device in the harbour...
I suspect that this sort of boat is not the most loved, consequently there does not seem to be too much info about.
What would you suggest? The one that seems nearest to fitting the bill is the Cox/Priorycraft Master Mariner which looks far better from behind...any opinions?
And yes, if I had won £25k rather than a measily £25 on the Premium Bonds this month I would have bought a Fisher...or maybe even a Haber.
So as both boats were out of the water I measured them. Although I did not have a tape measure I put some rope on the waterline of both and the Colvic 24 is longer than the Fisher 25. Reason. the Fisher has the rudder hung on the transom and the 25ft included the width of the rudder whaereas the Colvic 24 has the rudder underneath which is not included in any length measurement.
Personally I would consider a Colvic 28 as long as it is well sorted. Unfortunately these Colvics were originally powered by BMC Diesels and and engine parts are virtually unobtainable. Some people have re-fitted ISUZU engines and if you can find a re-engined one you could get a decent boat at half the price of a Fisher 25.
PS I saw a Fisher 25 at Liverpool Marina in a cradle and the whole hull under the water line looked as if it had smallpox, whereas in this case it was Bigpox, being osmosis. On the Colvic 24 there were about 10 "blisters" easy to treat.
