Aboard connections
PabloPicasso
12 Feb 2010
As I work on the 12v and shore power systems I found three mains cables spliced through a choc box connector wrapped in insulation tape, and not screwed down.
I want to replace this, but with what?
A 3 way domestic mains box that can be screwed down?
I have a box for wago connectors is that safe to use on a boat?
Other options?
Other options?
Wago connectors are fine on a boat. They need to be secure and the box needs to be waterproof if in a damp/wet location.
That said, what are these mains cables ? Type, size, going to and from where ?
It's the shore power/mains connecting cables to various 3 pin sockets. It's below a bunk in the aft cabin, so shouldn't be wet!
3 cables join in a choc box connector covered with insulation tape that is not restrained.
A wago box screwed to the bulkhead would be easy enough.
I'm using shore power more often now the boat is ashore than when afloat (boat was/will be kept on a mooring)
Power tools, kettle, dehumidifier, battery charging....
Why not redo the whole thing. Fit a small garage type consumer unit with RCD/RCBO and a couple of MCB's .
He already has a consumer unit Mains power
Would be useful to know what's in it and as i asked earlier, what type and size is the cable.
It would be unfortunate to give any advice and then find out that the cable was totally unsuitable and caused a fire, or there is no RCD and someone got electrocuted.
@PabloPicasso can you answer those questions please, with pics, preferably.
Yup OK I didn't connect the two. Yes pics. would help including the consumer unit ;)
Only one mcb is in use, so I could swap them for one double pole mcb.
There are four Sockets on board. A single in the aft cabin, a double near the galley, a single on the main switch panel, and a single in the fore cabin.
There are four Sockets on board. A single in the aft cabin, a double near the galley, a sigle on the main switch panel, and a single in the fore cabin.
Wouldn't bother with a double pole MCB, i'd think about changing the RCD though.
Yes, actually I have changed them. These are in place now.
What do you say the potential issue with the RCD was?
The original RCD just looks old, they don't last forever.
The MCB you fitted is only 10A, a standard kettle will trip that.
Despite being asked 3 times you still haven't said what type/size the cables are. It's difficult and dangerous to give detailed advice without having all of the facts.
