Aboard connections
PabloPicasso
12 Feb 2010
As I work on the 12v and shore power systems I found three mains cables spliced through a choc box connector wrapped in insulation tape, and not screwed down.
I want to replace this, but with what?
A 3 way domestic mains box that can be screwed down?
I have a box for wago connectors is that safe to use on a boat?
Other options?
Other options?
Wago connectors are fine on a boat. They need to be secure and the box needs to be waterproof if in a damp/wet location.
That said, what are these mains cables ? Type, size, going to and from where ?
It's the shore power/mains connecting cables to various 3 pin sockets. It's below a bunk in the aft cabin, so shouldn't be wet!
3 cables join in a choc box connector covered with insulation tape that is not restrained.
A wago box screwed to the bulkhead would be easy enough.
I'm using shore power more often now the boat is ashore than when afloat (boat was/will be kept on a mooring)
Power tools, kettle, dehumidifier, battery charging....
Why not redo the whole thing. Fit a small garage type consumer unit with RCD/RCBO and a couple of MCB's .
He already has a consumer unit Mains power
Would be useful to know what's in it and as i asked earlier, what type and size is the cable.
It would be unfortunate to give any advice and then find out that the cable was totally unsuitable and caused a fire, or there is no RCD and someone got electrocuted.
@PabloPicasso can you answer those questions please, with pics, preferably.
Yup OK I didn't connect the two. Yes pics. would help including the consumer unit ;)
Only one mcb is in use, so I could swap them for one double pole mcb.
There are four Sockets on board. A single in the aft cabin, a double near the galley, a single on the main switch panel, and a single in the fore cabin.
