MapisM
Apologies for the cryptic title, but I thought to post also something trivial, on top of one of the usual technical issues...
Let's start with the latter anyway - it's a mobo forum after all, 'innit?
Last season, I had some erratic troubles with the hydraulic flaps.
Most of the time, they worked flawlessly. But occasionally, for no apparent reason, they didn't move one bit.
When pressing the buttons, the electric motor always started normally with no strange noises, and each of the 4 electric valves (left/right, up/down) also worked as usually, but the pressure gauge on the pump unit was stuck to zero.
So, it was reasonable to expect that the problem wasn't electric, but rather somewhere in the pump.
Long story short, below is the pump body opened.
The bad news is that according to a pump specialist, the groove which is highlighted in the pic was formed by the inner gear, possibly due to running dry, and that is enough to make the pump cavitate, without building up any pressure.
The same chap suggested that the external body alone is not available as a spare part, hence the pump should be replaced.
Now, aside from not understanding how and when the pump ran dry, considering that the oil level has always been close to the max, I would be curious to hear if anyone more knowledgeable than myself on these components (i.e., probably most forumites!) agree on this diagnosis.
And if so, also any suggestion on suppliers of these things would be most welcome, since it would be silly to replace the whole controlling unit, with its motor, valves, etc. - I am attaching also a pic of it, just for reference.
Thanks in advance for your help!
Oh, but you might wonder why having some pasta could be such a consolation, considering also that in IT a decent pasta dish isn't exactly hard to find.
But as it happens, yesterday a small restaurant nearby organized an evening focused on a type of pasta which we never tried before.
So, after a day spent at the yard fiddling with flaps and other stuff, we couldn't miss it, could we?
And it turned out to be a great discovery indeed.
So much so, that a bit of googling revealed that just a few years ago, the thing was even covered by the BBC.
An interesting and unusual reading, for those of you who on top of boating appreciate also VERY peculiar (but excellent!) food... :encouragement:
