H/V Vega
You know how outboards loose power when repeatedly stored for a few weeks between uses? Well here is why and how to prevent it. This trick is not for long term - over the winter- type storage which should be done differently. It is also best for the average cruising sailors dingy outboard - not the big monsters seen on some boats. When you take the motor off and store it without proper preparation there is fuel and oil in the carburetor. When the motor sits that fuel evaporates through the fuel jets depositing a coating much like a varnish. You cannot easily see this, but it slowly closes the jet preventing the proper flow of fuel. Do this often enough and you get a motor that is the very devil to start and runs like an old lawn mower giving little or no power.
To prevent this before you take the motor off the dingy turn off the fuel and run it at idle until the fuel in the carburetor is consumed. No fuel in the carburetor means no varnish in the jets. Now you can store the motor safely and it should run perfectly when you need it again. Just thought I would share this with you. It was in our last newsletter at http://www.sailvega.com/newsletters/november2010/december.html along with a bunch of other sailorily stuff.
