Beneteau381
Got back on the boat last night. The CO detector was pinging occassionaly. Nothing on board being used that could produce CO so I took the batteries out and went to bed. Checked them this morniing and still at 1.49 volts so not that. Then I noticed that there was a sticker on the detector. Basically after 7 years the thing is toast and has to be replaced.
So I took it off the roof and binned it.
This afternoon I came down in to the saloon and smelt a familiar smell similar to 3 years ago! It was toasting battery! The BM1 was showing 14 plus volts and 13 amps charge! Off with the charger and solar controller and in to the battery compartment. The end battery was hot, very hot!
I let it cooll a bit then disconnected it and removed it. It was stinking and v hot.
The moral of the story? If your CO detector goes off and the internal batteries are ok, then a check of the main boat batteries might be in order!
