steve yates
My longbow has 5 solar powered vents on the coachroof, 3 are very old, just screwed into the grp and the little solar panels inside have crumbled away. Two look newer and appear to be through bolted, the solar panels look inbetter nick but havent dismanteled those yet to see if they are actually working.
Assuming they are not, I have 5 old vents, and it appears replacements are around the £50 mark. Now I don't want to spend £250 on these at all, I have plenty other candidates for spending on.
So do they need replaced? Do they still work as vents without the spinning fans or not? And if they need replacing, what would you recommend? I have seen the plastic mushroom ones on ebay for £15 each, but I can just see them getting kicked or stood on and breaking, so I've discounted them. Are the butterfly (?) types any good?
I want ones which will keep water out if waves are coming over the deck.
Thanks.
Thanks.
