490 Navtex
Have you got all the stations that you are within range of turned on? My experience of navtex is very limited but I had a load of trouble trying to get it set up to print the messages that I wanted and not a whole load of other stuff.
I think if you are on the move, you might loose stations and not be set to pick up the ones you get within range of?
Er, all this may be a laod of rubbish, can anyone put me right?
burgundyben, coolest of men, by all I'm called, cool burgundyben.
Yes!
Get the Niton broadcasts more often than not - miss a few now and then, but OK last few days. Only problem I am having is that I can't seem to turn off Monsanto which has only started popping up in the last few weeks!
I'm in Plymouth and have an ICS Nav6 plus
Cheers,
Jerry
Re: Yes!
Thanks for info one and all.
I am receiving 518 fine, but the only 490 I have received during the last couple of weeks has been some rather garbled French - I check the boat every few days.
I have a newish Nav 6 plus which was working OK, and which still seems to be correctly setup, but I am no longer receiving Portpatrick (I am based in Largs, Scotland).
