Dogone
It used to be recommended, Is it a bad idea to balance overnight in parallel?
Sorry, I wasn’t clear enough, I meant to say the way previously recommended (actually by Collins) was to charge up in series, to disconnect and then re-wire all cells in parallel and then let them sit overnight or even better, for a couple of days with no charger connected so they could balance themselves. Left like this there will be a small current flow from the slightly higher voltage cell to the lower voltage ones.If you follow the downloaded instructions to the letter in setting the voltage of the PSU before connecting to the paralleled cells then in theory you can't overcharge. However, given so much is at stake, I checked the voltages of all cells every twenty minutes. When I needed to sleep I stopped the charging and just left them connected in parallel with no charge. This does nothing but does no harm either. The parallel stage of charging (following the charging of the 4S pack at 12 volts) took 8 hours.
Is that a bad idea now?
Quite sure, especially now I just checked my not so bad memory.Are you sure that was Collins? He does recommend a different method which is to top balance progressively in parallel to 3.4v, 3.5v and then 3.6v. That doesn't seem to confer any additional benefit to the method I linked to and used.
It is generally reckoned that cells don't balance in parallel unless there is a charge running through them so I don't recognise leaving them uncharged overnight or longer as standard good practise. Of course thinking has changed a fair bit in the last few years - not long ago balancing to a higher voltage - e.g. 3.8v per cell was common. No-one would go so high now.
He also said to top up the balance to 3.8v with a bench top supply after letting it sit for a day or two.
See:
LiFePO4 Batteries: Discussion Thread for Those Using Them as House Banks - Page 215 - Cruisers & Sailing Forums
c) kill the LifePO4 pack as well I guessI'm still trying to get to grips with the basics of this technology, so forgive me...
If the BMS does not communicate, this is bad because when it disconnectes
a) you could fry your alternator
b) you could, without warning, lose your power source to nav instruments etc
Are those the only considerations, or is it more complicated than that? (not trying to downplay that the above reasons are serious, just considering ways to work around them).
c) kill the LifePO4 pack as well I guess![]()
Again excuse my ignorance, but why would this happen? Is it because a cheap BMS will only cut in when the battery is dangerously out of line? I see a lot of them don't disconnect until 10v, which sounds far too low for a happy and long lived battery.
Thanks. Every day is a school day. Most of the really cheap drop-ins have a 10v cutoff, and I presume that can't be changed. I presume that the only way you can really use these batteries in practice is to manually monitor the voltage and disconnect. But I suppose I do that already with my lead-acids.Yes 10v is very low for disconnect. This BTW is one of the cautionary factors to be kept in mind in considering the Zwerfcat hybrid system. That involves using the BMS to routinely take the BMS on and off line. That needs some conservative settings for the high and low voltage disconnect parameters. Those wouldn't be found in some of the cheaper drop-ins. In fact Zwerfcat use their own external configurable BMS. It would also be achievable with the 123SmartBMS.
Is there an idiots' guide for BMS anywhere?
