luke collins
The battery bank is a bit small to use the inverter to take full benefit of the solar installation. It works OK during the day if there is a decent amount of sunshine and we don't overdo it with cooking, but because of the size of the battery bank it gives the batteries a hard time, sometimes. With them being lead acid they also charge slowly (compared to LifePo4) so don't fully take advantage of the available solar yield.
The batteries are a few years old and likely due for a change soon anyway. It looks like i can build a LifeP04 battery for about the same money as wet lead acid and less than AGMs, so it makes sense to change now (soon).
The boat is also fitted with a 12kva generator, but we don't use it much. We did use it a little before i fitted the inverter, mostly for light use when underway, as we are all electric. Seemed a bit extreme using a big generator to boil the kettle. We have a 1kw kettle, which the inverter copes with comfortable and when underway the alternators will put out more current than the kettle uses.
We do exactly the same with a hotel room kettle. Works fine even at anchor with no engines for a few brews. We run also the air fryer off the 2kw inverter and 300 amp of house batteries. Been fine for one night on the hook
