P4Paul
I had to make less than ten outputs with winds of 15 knots and less waves less than 1 meter.
And while I feel for you and hope you find an answer to the position you find yourself in, I struggle to comprehend that 10 trips in calm waters result in the outcome shown in the photos.
My view means nothing. The dealer's opinion is irrelevant as it is just an unqualified opinion. Without being rude, the survey you commissioned is a report based on getting the result you want.
Bavaria are not commenting until they can start taking the boat apart and see what the real issues are.
Somewhere there appears to be another survey but I am not sure you have shared any information from that one, if you have, then it hasn't been made clear.
There is a question about the timing between build and handover and now I think you suggest that the dealer used the boat as much as you did.
You are absolutely right, this shouldn't happen to a boat of this sort in normal use. You have a very unique issue which doesn't appear to have happened to any of the other 100's of same, hull, deck and hull mouldings.
It is Bavaria you need to be having a constructive conversation with, but based on the above, I personally think they are doing the right thing by offering to return the boat to the factory, carry out a full repair, fully warrant the outcome and return the boat to you in time for the 2016 season.
Once the boat is returned following repair, you then will have all the information required to make a partial or full refund claim.
I hope you get a satisfactory solution without being too costly. Let us know the outcome when the time is right.
