12V Macerator pump
ianc1200
6 Dec 2005
Frinton on Sea
Anybody got recommendations about a 12V macerator/pump with a 38mm outlet? All the one's I can find are 25mm outlet. I'm re-plumbing the holding tanks in, unused by previous owner for some 18 years. So toilet to divertor valve, then to holding tank, then along with standard pump out a Y valve to a macerator/pump, then to the 38mm pipe from the divertor valve to the seacock. Could of course simply use an adapter to get back to 38mm, but if there was a macerator/pump with a 38mm outlet would be a bit simpler.
Tranona
10 Nov 2007
It is common to pump out to a dedicated 25mm outlet from the tank rather than back to the main outlet. Pretty sure moat macerator pumps are 25mm. ,Plumbing is 38mm from toilet to Y valve to seacock and tank. Shoreside pumpout and 25mm outlet with pump to dedicated seacock.
ianc1200
6 Dec 2005
Frinton on Sea
Thanks. I'm guessing there's not too many boats who want to pump out from holding tank to seacock so I might struggle to get one.
