ctelfer38
A query for the electrical circuit experts on here. Having solved earlier battery power questions through advice on here, I return with another problem.
Firstly the system
I have a Volvo Penta 2003 engine with standard alternator feeding an input to a 70 amp Volvo Penta diode splitter sending a charging current to two battery banks. Domestic bank is 2X80 amp deep cycle and Engine bank is 1x105 amp starter battery.
I have an AC mains 11 amp charger for battery maintenance when alongside.
The splitter shows a drop of .56 from input to output which I believe is normal.
The problem.
The charger does not 'see' the batteries when connected through the splitter and will work only when the splitter is bypassed. On the one hand I understand why, as the spliitter should not let current flow back from the output post to the input. On the other - how can the charger be connected so that the splitter can do its job? What do others do?
Thus far I have identified three solutions, none very elegant.
1. Revert to a 1/2/All/Off manual switch.
2. Rig two battery chargers.
3. Change to a mains charger which does not need to 'see' the batteries before commencing charge.
Are there better solutions I have not identified?
Comment welcomed.
CBT
Firstly the system
The problem.
Comment welcomed.
CBT
