10hp 4 stroke versus 15hp 2 stroke
rigpigpaul
5 Aug 2004
Merseyside & Yalikavak
Hi All, I now have a 3m rib dinghy and I need an engine. I am looking at a 10hp 4 stroke or a 15hp 2 stroke. I believe they are similar in weight. I will only be using the dinghy occaisionally so fuel consumption is not high on my list. I do want to get onto the plane with two people and bags of shopping. Quiet as possible and maybe an electric start would be nice. The engine will have a tiller arm.
All tips will of course be appreciated. What would you buy, if you knew then, what you know now!
RPP
NornaBiron
6 Jan 2009
Greece
www.flickr.com
We have a 10hp 2 stroke with our 3.1m rib. It will plane with two of us but not with the month's shopping too. It's heavy, we manage it by hoisting with one of the dinghy davits, and it's thirsty. We love it though, it's great for exploring. We also have a 2.2hp 2 stroke which we prefer for every day use. It is easy to handle, sips petrol and gets us ashore safely in most conditions that we'll leave the boat in, if a bit slower than the 10.
The 10 is the same weight as the 6hp 4 stroke that we use to have so I suspect that a 15hp 4 stroke will be quite a bit heavier than the 10.
geem
27 Apr 2006
Caribbean
We have a 2.9m rib with tohatsu 9.8hp. the engine weighs 26kg. This set up planes with two of us and a little shopping. The engine is very economic to run. On a three week holiday we used no more fuel than a pal with a 3.5hp on a dinghy with four people on board. We did a lot more distance in our rib as well. the twin cylinder 2 stroke 9.8hp is easier to start than our single cylinder 3.5hp engine as you don't need to pull it so hard.
rivonia
22 Sep 2008
on the move as live aboard
When we were in the carribean we had a 3m RIB with a 10hp 2stroke it planed with two people and some shopping. In the Med we had a Rib the same BUT had a 4 hp mercurey 4 stroke... Disaster. It was just too heavy for us to lift. It did plane though with two peolple just. Go for a two stroke every time.
david_bagshaw
5 Jun 2001
uk
We have a 3.2 mtr rib with 8 hp 4 stroke, planes easily with 2 + shopping, however we fitted fins to the cavitation plate to improve its planing performance, back to that before fuels in europe were reduced to the lead free low ron standard.
GSL
8 Mar 2008
Me Cheltenham, boat Sant Carles de la Rapida
Go with the two stroke every time.
They use more fuel, but in reality how much do you use, so much lighter to lift on or off and soooooo much easier for a woman to start.
I have had a 10HP Mercury on an Avon 3.2 RIB, struggled to get going with more than two people on it, I even bought a set of Lifting Fins for it from USA, still not what I wanted. Still have the Lifting Fins / Tabs if anyone wants to buy a set.
Changed to a 15HP Mariner two stroke, brilliant. So much power to spare, half throttle got you everywhere on the plane. So much easier to start also.
I now have a 2.8 meter Walker Bay with a 13.5 HP Yamaha 2 Stroke, great engine.
Would never go back to a four stroke on a RIB. The weight alone makes it a no brainer to me.
Graham
GSL
8 Mar 2008
Definitely the 2 stroke - if you can buy it legally - it's lighter, will certainly plane your RIB and will probably be more reliable.
Hi Charles
I am not disputing your comment, but I would like to hear clarification as to why you feel the two stroke is possibly more reliable.
I have always felt that the two stroke can suffer slight fuel feed problems from "gumming up" the carb when or if fuel is left too long in the float chamber.
Would appreciate any experience you may have had regarding four stroke reliability. No question in my mind, two stroke every time.
Graham
rivonia
22 Sep 2008
Hi Charles
Would appreciate any experience you may have had regarding four stroke reliability. No question in my mind, two stroke ebery time.
Graham
You will find that if you leave petrol in the FOUR STROKE and do not use over winter...It also gums up!!
GrahamM376
30 Oct 2010
Swing mooring Faro
Hi Charles
Graham
I agree with Charles. From personal experience I have found 2 strokes to be more reliable and have never suffered from fuel gumming up. Mechanically, there are more potential problems with a 4 stroke which, unlike 2 strokes have a camshaft, valves and tappets to adjust.
charles_reed
29 Jun 2001
Hi Charles
Graham
Basically because it's got fewer moving parts - with modern ignition systems the main disadvantage of 2 strokes appears to have been overcome.
Certainly you can get an oiled-up carburettor but the solution is simple, always run the engine to a stop by turning off the fuel.
GrahamM376
30 Oct 2010
Swing mooring Faro
I think the gumming up issue is overstated and could mainly be with older machinery with more oil in the fuel. Yes ir does sometimes happen but, if it were the norm, very few people wold be able to start their lawnmowers in the spring. I dug my petrol driven power washer out this morning, added some new petrol to the old and it started after a few pulls, having been unused for around 12 months. Never had problems with 2 stroke outboards gumming up during 16 years use.
pyrojames
9 Aug 2002
Cambridge
transat2013.blogspot.co.uk
I have a 15hp Mariner (Yamaha build) on a 310 RIB. Great combination, planes easily 4 up, fast to run in from outer anchorages. Too heavy to lift so need to use a halyard to get it aboard. Can just struggle to carry it when needed and get in/out of the car. Old reliable and was cheap from ebay, along with RIB and trailer...
