PaulRainbow
One does the have to add a third "emergency combining" switch so that the circuits can be paralleled and operated from just one battery, or from both, if the need arises.
The third switch adds a lot of value to the system. It allows for emergency starting from the domestics or emergency domestic supply from the engine battery. It's presence also means that either bank can be used to run the whole boat, should a bank need to be quickly isolated. A very simple and foolproof system when everything is working as it should, but a highly flexible setup when things hit the fan.
One also has to separate the alternator output from the starting and engine supervisory circuits and use a VSR, a low loss splitter , Sterling A2B charger or some other means of independently charging two batteries at the same time.
No need to separate the alternator output if using a VSR.
There are ways of simplifying such a set one. Eg by using a BEP VSR switch cluster or a Blue Sea dual circuit switch with battery combining. The latter is a neat way of simplifying the switching. reducing it to just one switch but retaining the advantages of the multiple switch arrangement.
The BEP cluster is pretty expensive for what it is and it's connected in a less than ideal way. The default connections don't allow a bank to be isolated, easily fixed though. The basic cluster is about £150 and only consists of three switches and a VSR. The "distribution panel" consists of the same components, mounted in a panel, for a shocking £250. I designed a panel that fits over the hole left by the Vetus 1-2-B switch, which takes three BEP or Durite switches, the panel, three switches and a Victron VSR come to a total of £142. This is an example, it doesn't cover the hole, for a reason, although it usually would.
The BlueSea switch is a nice bit of kit, vastly better than the 1-2-B switch. My only minor criticism is that it doesn't easily allow for a bank to be isolated, one would have to take a battery lead off. Unless switchable breakers where used in place of battery fuses. Nonetheless, a minor point.
