Oughtred Tammie Norrie build
Rabs
16 May 2022
Hi everyone,
New to the forum but thought I'd share something I've been working on for a few weeks now. Feeling pretty proud of how it's turning out!
Very glad I spent the time to build a full jig rather than freehanding it over the moulds. Having it fully ribbanded made construction very easy as I made up a little jig for my router so bevelling the planks took about 2 minutes per plank.
Now got to get to work on the fittings and order some more timber for the spars.
In other news - is there a market for selling construction moulds? It seems such a pity to rip it up now that I've finished with it but I don't have space to store it.
sarabande
6 May 2005
Big welcome to the forum Rabs. What a lovely workshop: you are about 500 times more organised than me ! We love boat construction threads, so if you have the time to start one in the PBO forum, it would be followed by lots of keen DIY people.
The only query I have about your plan to sell the mould is that of possible copyright
DownWest
25 Dec 2007
S.W. France
Wow, a very nice workshop! I built a Whilley Tern, but just had enough room to get round each end. With only four planks per side, I just used the moulds.
On selling, why not ask Iain? He is very receptive to questions. I expect as long as a new builder buys a set of plans, then using existing moulds would not be a problem.
Rabs
16 May 2022
Yes, I was planning to make it clear that the buyer would need to buy their own set of plans. The jig itself isn't really sufficient to build the boat anyway without the plans, it'll just save someone a bit of time and help them make a neat job of it.
Not come across the PBO forum. I went to Boat maintenance advice, sailing and motor boats, practical advice | PBO and clicked forum. It brought me here. Is there another forum out there?
Merrick, thanks for pointing me to the facebook group. I haven't logged into facebook for about 10 years now but I'll go and take a look!
I understand Iain only uses post. I'll have to see if my handwriting is still legible.
When I get home I'll take a couple of pictures of my secret electric motor I've built into the skeg for when I'm feeling too lazy to row.
Thanks everyone
DownWest
25 Dec 2007
S.W. France
Thanks everyone
Iain uses e-mail too now.
This is the YBW site, but if you go to top and select forums, the Practical Boat Owner one is the first on the list.
Devlin Boats shows a rudder mounted electric motor on a couple of his designs.
Rabs
16 May 2022
Hi everyone, a quick update about my build. I've been making slow but steady progress with the fit out:
I'm part way through building up the centreboard case and have run into a bit of a problem. The plans look like this:
Which, when you overlay them gives you this:
Which doesn't fit at all. The plans call for a cap on top of the centreboard case so it definitely isn't supposed to stick out of the top . Fortunately I saw this before I got busy with the saw!
I'm uttely confused because loads of people have made this boat from these plans before and nobody else seems to have had this problem. Any ideas anyone on what I'm doing wrong?
Hacker
4 Nov 2015
Falmouth
The drawing of the centreboard (3rd one in your post) appears to show the caps finishing both fore and aft implying an open top.
DownWest
25 Dec 2007
S.W. France
Are the 'caps' thwarts, with an open top? The board in your drawings will swing in an arc well above the case and, I presume, the fwd top has some stops that limit the swing down by contacting the top of the case?
Rabs
16 May 2022
That's right, the bits fore and aft indicated on the plan with woodgrain shading are the thwarts. There is definitely a capping piece as well along the top of the case. What I may have overlooked is that the capping piece might, itself, have a slot in it for the board to peek through. I'll try reading some other builder's threads to see what they've done (should probably have done this first)
DownWest
25 Dec 2007
S.W. France
Again, if you trace the swing of the top point of the board around the pivot, it is well above the top of the case.
Reply from the UK builder, not on this site:
I don't have a login for YM.
If you can tell him, that the centerboard case is only capped aft, so that the centerboard is then held, in a just 'off vertical' position when its down when the board touches the cap. Its open mid to forward and the centerboard sticks out the top, as his overlay shows. I had an auto release camcleat to hold down the centerboard via fairlead on the top cap if I remember.
Picture of Tavy Wooden boats Tammie norrie build shows it...
http://www.tavywoodenboats.co.uk/wp-...ld-photo-6.jpg
I prefer to loft the centerboard case/ keelson intersection out and then make a pattern to check then the real piece. I had maybe a 1mm gap that's all, and that was caused by the bend in the keel/ keelson as the boat was proppped/ gravity and could be adjusted in situ to get a perfect fit. Sometimes taking more steps gets to the finish quicker. Seen plenty of builders finish with a leaky case joint. I used plenty of thickened epoxy and tape inside to help reduce clean up time. Some builders use a big squidge of Sikaflex instead, not tried it.
Tell him to sweat the fit and take the time to get it vertical (as far as possible). Dad bought a Gannet (built by a carpenter rather than a sailer) that leaked from the case and it was a bit of a job to locate the leak point.
Hope this helps.
DW
Rabs
16 May 2022
Amazing, thank you. That makes a lot more sense. I knew it had to be a 'me' problem! Right, time to get cutting!
DownWest
25 Dec 2007
S.W. France
Get 'The Sailmakers Apprentice' and make your own. I did and they set very well. Jeckels quoted a good price, but I spent about £110 on cloth and tape. Very satisfying.
