wooslehunter
I just drilled out & tapped my alloy mast foot for new larger bolts that hold it to the mast. The threads had corroded away completely. The best way stop further corrosion seems to be to use zinc chromate paste.
However, to get access to where the cables come through the mast at the bottom, I need to remove the foot. This isn't very often but does need doing from time to time. How hard does zinc chromate paste go? If I use this on the threads will I get it apart again. Is there a better way?
