Sorry in advance if this has been answered before and I missed it ... and I've never owned a mobo but hope to someday, but why does one need underwater lights?
Fair pointMike, i'd place them lower rather than higher. When the boat pitches in a swell at anchor you ideally don't want them coming out of the water, as that actually is slightly anti-social because it's night blinding for people sitting in the cockpits of neighbouring boats. Not a big issue of course, but I can't see any big downsides to mounting them lower.
I'm also planning to fit some, but i'm only fitting two as that's all I want.
For the full blingtastic effectTo address Nick's point you could easily wire the outer pair to be separately switchable.
A project for next year I think!I would also consider fitting the second pair on the hull, pointing to the sea bottom.
You probably will end up fitting the colour change type, I fitted three at the back and one either side ... Works well ! Will look out some photo's when I get a min. Sorry Searush I know how you LOVE this subject !![]()
Mike, Here you go ........ Three at the rear and one each side the effect on the water is good ........
I don't have a MOBO but a sail boat.
I have just been given a present of 3 not 'under water lights' but 'under boom lights'.
Mount to the underside of the boom to illuminate the cockpit. These are LED lights mounted into some alloy section. I'll post a picture once fitted.
Under boom lights now fitted. Illumination of cockpit is excellent.
Nice! Got any pics with the lights on in the water?
Cheers
Jimmy
Having read through this thread I think we are definitely in need of a separate old farts forum, where they can mutter to each other about underwater lights, speed boats and swap tips on hemorrhoid creams.
