bluerm166
Use a tape.
OTOH, if it isnt...If it's worth doing...
A friend of mine kept a tin of TBT clear boot-topping paint that he used over a white strip for many years.I tried various paints but best results was painting 2 x coats International Toplac which you can scrub without it coming off and lasts very well
An alternative viewpoint, if you take a positive outlook, could be that the yard are giving good advice based on their extensive experience. That should resonante with the users of this forum.You say the yard is pushing you to have the divider - the question should be - is the yard short of work and are you just another wallet to empty?
Jonathan
Absolutely this. I used 10mm vinyl tape. Cunningly I did mine in yellow so it hides all that murky yellow solent staining.It looks better with. I opted to do it in vinyl - the idea being that it's easy to get right, and easy to replace when it gets grubby.
I personally like it better.I'm not bothered really .. but feel that it invites grimey look and stains ?
I have time to decide .. so far I've said I'm not fussed and really want the hull sanded and repainted .... which led to the suggestion.
Go on ... Yes or No ??
