awol
Right you smarty pants, I know you are ready to tell me that multi starter button pushes are a common Yanmar problem caused by bad connectors and thin wiring and the sure answer is a secondary solenoid or a push-switch close to the motor. But after fannying around removing panels, breaking and making connectors, and not making an iota of difference I connected the power and solenoid terminal at the solenoid and ...... still nothing but a click. A short across the big terminals produced a satisfactory arc and the motor working so I have a solenoid that clicks but doesn't close its contacts.
Manual operation shows occasional connection but it definitely ain't happy. I can't see a way in to the contacts - I am considering fitting a mini-solenoid across the terminals, I could just short the terminals, or I could buy a new motor. Anyone got a better answer?
