Polarsailor
Active Member
I need to change the gear lube in my Yanmar 2GM20 gearbox. Looking at the dip stick it appears red like ATF fluid. According to the Manual it should have the same oil as the main engine, 20W 40. The gearbox is I think a KM2P. Larger Yanmar gearboxes I believe do use ATF fluid. Has anyone come across this before.
Not over keen on switching to 20W 40 as there would be residual ATF fluid in the gearbox even if I pump it out. The ATF fluid has been seems to have been fine and I haven't in fact changed it since I bought the boat a few years ago. Does anyone run this gearbox on ATF fluid and if so has it been fine?
Cheers Keiron
Cheers Keiron
