Potato Head
I have a 1GM10 in my yacht and the alternator is not giving out charge. Had an auto electrician check it out and all is ok. The problem appears to be with a relay between the wires that come out of the alternator and go to the charge light. The two wires come out of the alternator and pass through a six pin relay. From here a +ve and -ve wire go to a set of terminals that aren't connected to anything. One -ve wire is on its own and is connected to nothing. The other two +ve wires and one -ve wire then go to a plug which is connected (via a +ve and -ve wire) to the charge light. When I bypass the relay the alternator charges without issue (13.8 V).
Does anyone know if I am damaging anything by doing away with the relay? It doesn't appear to be there for anything on this boat (a Mumm 30) - perhaps its for other installations?
Thanks guys
Thanks guys
