There are some previous threads. This isssue only came about this season. Once started runs fine for 8 hrs no problem.
1/ I suspect an air or fuel issue not starting it on the button as should. It is as though I am having to bleed it every time I start from cold. Can this cause it to not catch and then bounce back to start?
2/ it seems as though enough power is there as it can be "force started" with speed on the starter. It may be an idea to boost it with an added battery and jump leads?
Any thoughts appreciated.
