Yamaha F4
Ian_Rob
31 Jan 2008
The steering of my Yamaha F4 has become very stiff irrespective of the tightening screw. It rotates much more easily in one direction than the other. Is this a known issue?
May be lack of decent lubrication ..... there are no grease nipples shown on the parts diagram ... is that really so?
I think Id simply remove the tilt lock and unbolt the two halves of the swivel housing and have a look-see.
If nothing broken clean up , lightly grease the swivel bushes and re-assemble. There's not a lot of rocket science in there.
watch out for the two little springs on the tilt lock , noting how they are fitted.
If it's the same as the F6C there's a friction band inside the leg. As you tighten the lever it tightens the band onto the inner part of the leg & prevents it's rotation.
On my engine the far end (non threaded) of the threaded part of the lever had come out of the band & tightening the lever distorted the band rather than tightening it around the inner part of the leg.
It is fairly simple to remove the cover & re-seat the friction band.
See pic below. 37 is the friction band; 38, 39, 40 are the tightening screw.
Thank you for the replies, comments and the diagram. It’s odd - it would only easily rotate in one direction when I made the post but yesterday morning, without having touched it further, it was free again in both directions. I need to take it part I think.
