Yamaha 15hp stuck in neutral
ontheplane
20 Mar 2004
Bristol UK
Hi all, desperately need some help.
Had an outboard on eBay - someone bought it and came to collect it tonight.
Because I'd been running it in a bucket with a bin bag to line the bucket (leaks) I'd not dropped it into gear to avoid chewing up the bag.......
Stupid
Because it now won't drop in or out of gear - the selector seems to have seized.
Question is - is this something I might be able to free off myself - how hard is it to get to the mechanism, can I spray WD40 in there??
Basically they turned it down (understandably) and I am now in a pickle.
I do not want to spend a lot on it as I am selling the motor - how can I get it fixed without taking it to a Yamaha dealer and giving them lots of beer tokens?
Thanks all
david_bagshaw
5 Jun 2001
uk
usually there is a gromit where the linkage goes into the lower leg.
on the rod is usually a rubber bellows. encourage some oil into the area and work the gear change and all will come free.
well it did with mine x2
fergie_mac66
28 Jun 2009
south yorks
also they wont go into gear if you have the tickover revs too high. If you have remotes and slow leaver is much above half the mechanism wont allow you to put into gear same with handle too high revs no gear change . honda 8 does same
mtb
30 Jan 2002
I found on my 5hp the gear change shaft had swollen up causing a very hard gear change. Once I sussed it got a file to it job done no more problems.
Don't ask me why the plastic / nylon swells up !
ontheplane
20 Mar 2004
Bristol UK
Hi All,
I don't think it's the linkage down to the drive that's the problem.
The arm you pull on is absolutely solid - so that may bear out what mtb said.
How do I detatch this, and then free it off??
I'll try and post a pic or vid later if I can work out how
fergie_mac66
28 Jun 2009
south yorks
on a smaller yam the shaft is plastic/nylon and it swells ,there is probable a grease nipple just under the shaft, carful dont put tomuch force if thats the prob, plus gas, easitoil gently work it loose grease gun on the grease nipple to pressure some in if you can .
